Engine run ?
Throwing this out to brainstorm considerations for doing a test run on my 2F which I recently put back in place on to my frame off restoration.
Current setup:
2F engine with oil cooler and smog equip...
Mounted to rolling frame with body still off...
Radiator and all plumbing in place with exception of front heater core
Tranny/diff/driveline in place
No wire harness in place, no coil in place...
All fuel line and pump lines in place as far back as the rear axle...
Oil cooler plumbing in place...
All exhaust in place...
Would like to do a test run and bring it up to temperature to check for leaks and whatnot.
Applying DC power to the starter turns it over...
Is it as simple as providng a fuel source (two lines into a small fuel canister of some sort) and providing power via the coil to the distributor?
Anyone want to outline a few step for me to follow? My main concerns are electrical. What power do I need to provide and where to (other than to the starter motor) to provide spark and not ruin anything? I know I have to "join" the heater hoses to loop the coolant, and keep the vehicle out of gear, but other than that I'm not 100% sure of what needs to be done and/or avoided.
Very lengthy for such a simple objective...open to all ideas!
Cheers,
Dave
Anyone ever try this?
TTT
Test run a newly installed engine mounted on the frame or engine test stand?
