Engine Rebuild Question
Not included.
For the intake break it apart in 2 sections. Get 4 cans of oven cleaner and Take it to the car wash. Wear goggles, long sleeves, gloves and pants. That oven cleaner will melt your skin if not rinsed off. Spray oven cleaner on the outside and inside and let sit for 5 minutes then spray it out. It will remove everything from the outside after a couple rounds of cleaner and power wash. The inside will get mostly clean. To finish the inside buy about 4 cans of b12 and some small wire brushes. Script the carbon build up and spray with b12. Takes about 2 minutes of scrubbing and spray per runner.
For the throttle body I used throttle body cleaner and a rag. There are some small ports that get clogged on the TB and the intake where the TB mounts. B12 and a small wire brush make easy work. Remove IAC valve and clean that port as well.
It's an easy job.
I would expect that might be an added expense. Most rebuilders do short blocks only. They are a machine shop and leave the rest of the work to an installer or mechanic. That said I would never have an engine rebuilt without getting a detailed list of agreed upon services, parts to be replaced or refurbished at the agreed upon price.
edit: And to also determine who is going to provide the warranty and associated labor for what period of time.
Oven cleaner is effective.
Could take it somewhere that has a hot tank. It's a parts washer and does a nice job too. Think I paid 20 or maybe 25 beans to some rathole shop run the two halves of the clamshell through the hot tank washer.
I had mine dipped/cleaned in the hot tank at my machine shop when they did the machine work for me. I think it was like $5-10 and came out brand new. I did my own rebuild minus machining so can't speak to that.
