Engine questions
Chev does make a 400 small block. But AFAIK the chev BB is 396 and up the block size if larger on the big block than on the small block ( more room needed )
Myrle
BOP offered a 350 big block called a 350 rocket.
Compression ratio = (V @ BDC) / (V @ TDC) (but corrected for headspace)
BDC - Bottom Dead Center
TDC - Top Dead Center
It's the change in volume as the piston travels from the bottom of its stroke to the top of its stroke.
Most testers are pressure gauges, which give a good approximation with a couple of assumptions.
