engine questions for a cruiser newb
I searched i promise. Can anyone give me a link about 80 engines,engine specs and swapability? I'm infatuated with my new wifes 92 cruiser, but it is gutless.I heard that the 93 engine is a better way to go.true? I'm in Ca. so whatever engine i go with has to be 92 or newer and retain all smog equipment. any help would be GREATLY appeciated.
P.S. I don't eally want to pay more than a grand for the engine itself,if that helps
Yeah, no. Sorry, but I'd look for better ways to optimize the 3FE you've got.
93 and later 1FZ-FE engine and in fact frame and all are very different making an upgrade like you're after very difficult unless you're in for a lot of fab and end up with a package that still doesn't make a lot of sense. You could sell the 92, and then buy a 93 for about a grand more.
If you're into engine swapping, a diesel (not sure which one is best) turns out to be a good swap, and if you don't mind American iron, a good small block chevy goes in nicely.
All a lot of work and way more than a grand to do. Find a friend in the 3FE crowd and convince yourself that it's a fine motor that'll last a long time and you probably won't have to worry about a head gasket replacement.
Welcome on :flipoff2: but I'm not sure if that's for you or your wife :D
it's stock, for now. I build rock crawlers regularly, so I don't sweat the fab work a bit. I was actually thinking about dropping a Vortec 350/700R4/208 combo in it, but wasn't sure if it was the easiest way. But since "a good small block chevy goes in nicely." I think thats the way i'll go.BTW, i'm not trying to be a cheap bastid, i just don't want to pay more than a grand for the engine itself. because i know how much can go into the REST of the swap.Guess i'll keep searching for a vortec swap then. Thanks for the input.I'll check back for more.
