Engine pinging on freeway, after replacing dist cap.
Salt Lake City, UT
So, I changed my distributor cap, rotor, all wires and plugs with oem items last weekend because I had a misfire when revving in park.
Old contacts were cruddy. The misfire is 95% gone, its only SLIGHTY noticeable at idle but goes away completely with any gas (in park, can't feel it driving)
Today, I thought something was loose in the engine. It donned on me it was pinging because it was only under load on the freeway. Sounded like marbles
I am on mid grade fuel, at 4000 feet altitude.
Anyway, I am open it any input, but my main question is how much should I rotate the dizzy to retard the timing 1 degree? I'd iike to try to just rotate a specific amount (1mm, 1cm?) Before getting a timing light and doing the FSM procedure.
So, I changed my distributor cap rotor last weekend because I had a misfire when revving in park.
Go to harbor freight and get the cheap timing light and follow the FSM. 5 minute job. Don't shoot darts in the dark.
Is the consensus to stick with stock timing?
Obviously, I'm assuming its advanced right now. I read that if it pings, just back it off till it stops.
I'm just thinking if I go to stock numbers I'll lose noticeable power?
If you have ping issues then start at 3 which is factory setting. If you still get ping then it's something else you need to fix. Usually you should not have issue at around 6 with a little more pep but everything else has to be in good shape. Reset everything to factory so you can have a baseline for troubleshooting.
I am at 6°. At 7° under part throttle up hill i have the slightest ping sometimes.
Every engine is different. Play around until you find the sweet spot.
Mine is the 3fe so stock timing is 7 degrees.
So I set the timing per the FSM, idle was at 650.
I haven't taken it on the freeway but I still heard pinging when warmed up, when in gear at idle.
My idle is great for 10 minutes, but when fully warm my idle drops from 650 to 600ish and I'm hearing pinging that instantly goes away with some gas. Or putting it back to park which increases the idle.
I have cleaned the TB, Air meter, looked around for vacuum leaks... Idk what to test for my idle issue.
Pinging is associated with acceleration, engine load, doesn't happen at idle. Are you sure the sound isn't injector click (normal), valve click (when was the last valve adjustment), exhaust leak, etc?
So I just took it on the freeway and with a lot of throttle at 65 mph I heard no pinging.
What I am hearing at idle is different than what I heard the other day on the freeway (which I've confirmed was pinging via online videos with good sound).
Its great that I seem to have fixed it, although i don't feel the timing was off by much at all. My dizzy looks like its in the same spot as before, and I had to move it around while starring at the timing mark to try and see the BB as it wasn't easy, so I never got a good "before" reading.
The sound at idle is more of a squeak, think of a knife against a clean plate sort of squeak. Very subtle though. I hear the injectors separate, also I just adjusted the valves.
