Recently started to get annoyed by the following two annoyances. 1997 LX450 with A442 Transmissiom
1. Engine would Ping lightly when pulling out from a light or lightly accelerating from low RPM'a with engine fully warmed up.
2. Slow down to about 10 to 13 mph then lightly accelerate and the RPM would jupm until the transmission cought 2nd gear.
Thied dumping the pan and refilling with ATF about 5 times, now the fluid at least looks like ATF. No Burnt smell when I started, but the fluid didn't have any smell.
Tried adjusting the cable for #2 and no improvement.
Tried Lubing the cable, little noticable improvement.
Adjusted the TPS Counterclockwise about 1.5 mm on the circumference. Both problems greatly improved.
I hear a Little ping maybe about once a week.
The transmission shifts into first below about 14 mph and then makes a nice shift into second under light acceleration.
Now I know that alot of you anal retentive folks are going to toot about messing up the emissions, but the reason that I decided to write this post is because the vehicle passed Pennsylvania Emissions today with flying colors. Soooooo, it couldn't be all that bad. So, my point is that small problems could be the result of one sensor shifting parameters. In my case, I think that someone foolew with the TPS since the usual Yellow dot of Paint was scrubbed off.
I am really interested to know what the Toyota manual says aboud adjusting this sensor.
Thanks
Tom
Thanks
Tom
