I have been using a comma semi synthetic Eurolite 10w-40 oil in my FZJ80 4.5 for last 2years, I have had a few leaks appear since I started using the sem syn, mainly around the usual oil pump area.
I decided to go to the loacal Toyota dealer and they suggested I use the Toyota
oil which is 5w - 40w it's just standard Toyota engine oil, it seemed very thin when pouring into engine, on the container it also says "for more MPG" which to me suggests that a thinner oil is less drag on the engine.
Since I have used this oil, I get a louder rattle when I start up the engine from cold and also the oil pressure gauge reads lower than usual at anything below 2000rpm
Not sure if I have done the right thing in changing.
