- Joined
- Apr 9, 2013
- Threads
- 236
- Messages
- 2,160
Hey Guys,
I just thought I'd post up a few pics of the replacement of the engine oil level sensor seal.
It's a one
job, with just four 10mm screws holding the sensor into the DS of the engine, just forward of the starter.
When you take yours out, remove it slowly and carefully. The arm descends down into the oil pan and you don't want to smack it around or bend it.
The little replacement seal is a bit bigger than a quarter, and has a small bevel on the inboard side of the seal. When you install the new one make sure you get the lip of the new seal under the slight metal shelf of the housing unit. Look closely at metal housing and you'll see a little groove - the seal seats in there.
The seal is part number 90430-27001, costs about two bucks. If you think you have a leaking oil pan and/or rear main seal, consider this easy and cheap step to eliminate a potential leak in the same area.
Happy trails.
It's a one
job, with just four 10mm screws holding the sensor into the DS of the engine, just forward of the starter.When you take yours out, remove it slowly and carefully. The arm descends down into the oil pan and you don't want to smack it around or bend it.
Happy trails.
