Engine off, 80 rolls forward in reverse?
Queensland and California
Can I get a reality check here -
I parked the Oz 80 on near level ground, no parking brake, hopped out, it started to roll forward. I jumped back in feet first to get my foot on the brake, and when I looked at the shifter it was in R. (I've made a bad habit out of parking in P w/o the parking brake on...:o)
Anyway, I don't recall any other 80 I've owned letting the car roll forward when R is selected and no brakes applied. I'm sure the LX450 doesn't allow this.
Can someone CAREFULLY see what the case is on your trucks?
Thanks,
David
Without actually checking it, with the engine off the pump in the transmission would not be making any pressure. Without pressure the clutch packs will not be engaged effectively putting the truck in neutral. If you want to try something put the trans in drive with the truck off and try pushing it backwards. It will go.
Any automatic tranny will let the rig roll when it is not in park. That's normal and expected.
Mark...
If it didn't roll in gear, there would be no point in having a 'park'.
-Spike
If the ignition lock out is working - that's true. You can't turn the key all the way back to off if the vehicle is in gear. and you can't move the shifter if the key isn't on "on"
I can't imagine why they would leave it off of a Aussie 80.
Do you have a brake pedal-gear shifter lock out? Where it won't shift out of park unless the brake is depressed?
That's what I thought Gumby. I know there is no way I have ever done this on the LX450 or the '93 80 I had in California.
And yes I can run through the tranny without the brake pedal depressed.
Much left off the Aussie models - from amenities like cruise control, to luxuries like rear heater, to what I would have considered a necessity in 1997 - airbags.
I guess it's like driving a seventies California car.
David
