Engine missing on acceleration
Chesterfield, VA
I have a 97 LC with 120K Miles. I ran it almost to empty the other day and it started missing very badly. Check engine light came on and I ran the codes and cylinder 5 misfired. I changed the fuel filter(full of crap) and it still missed. I just finished removing and cleaning the injectors (PAIN IN THE A&*). There was no build up or crap in the small screens in injectors. I sonic cleaned them in SeaFoam and replaced the FPR. I also cleaned the MAF with the correct cleaner. Cleaned the intire induction system when apart. The plugs look fine and the wires are less than two years old. The truck starts on the first key turn and idles fine, when accelerating from a stop it misses badly up to 2K RPM's. After that it runs Great! I can tell a world of difference in the feel of the engine at highway speeds. If you accelerate very slowly up to 2k the missing is not noticable. I mean very slowly. You can floor the pedal after 2k and it takes off like a rocket(at least in comparison to pre injection cleaning). What are the syptoms of a bad EGR valve? How about a bad 02 Sensor? It is almost dangerous driving the truck like this because it takes so long to get up to traffic speed. Help please!
Single cylinder misfire is not a symptom of a bad EGR valve or a bad O2 sensor.
It seems like a dead fuel injector. Carefully check the electrical connector to that injector. Did you have them flow tested or just a DIY cleaning? It might be clogged.
Check to be sure you are getting spark to that cyl and if OK, then pull the injector and see if the electrical is working (not sure how to test this... check the FSM) Plan to have all the injectors professionally cleaned and balanced.
-B-
B,
If the injector was dead or clogged, would the truck run great after it reaches 2k RPM's. That is my delema. There is absolutely no miss or hesitation driving normal speeds or excelerating from say 40 mph to 70 mph.
Todd
B,
I missed that.
Suggestion: Put some white-space in your posts to make them more readable. Random thoughts jammed together in one giant paragraph make quick reading impossible.
Check the Fuel Pump Relay. It has a low RPM and high(er) RPM circuit. It is possible that yours needs cleaning. Several posts on how to do this; one by SUMOTOY and one by Landtank. Also follow a similar thread that is within the first 50 posts yesterday.
-B-
