A while back when I first bought my LC I had it checked out for an exhaust leak. I was told that along with a leak my Cats were clogged and need to be replaced. This sounded reasonable to me knowing that they were OE and had 193k on them. In the process one of the OE sensors was broken during installation. The muffler shop replaced it w/o any charge. Soon after, the dreaded Check engine light came on. I then took it to find out what was causing the Check engine light to stay on. At that point it was thought to be the EGR Temp. Sensor. Well it was replaced and the light stayed off for about a day and a half. I was told that the computer error codes were vague for the 94 and that they would be guessing (I think also contributing to this is they were not familiar with the LC). My truck was running fine with the light on and with the miles on it was suggested that I drive it that way.
(Now 6 months later)
Yesterday I thought that I should try and reset the error codes by pulling the EFI fuse after reading some threads. To my surprise the Check engine light went off. It stayed off all the way to work (@ 15 miles) and then came back on when I was coming home last nite (@7 miles from work). The one thing I noticed, after I pulled the EFI fuse it ran rough at low idle with the break on while in drive. Other than that it ran fine. Now that the light is back on it runs fine and the low idle problem seems to be corrected.
The big problem I have with anyone here other that going to the stealership is that no one is familiar with LCs. There are plenty of Hummers and Escalades though. There just isn't that many in my area and the ones that I do see are Mall vehicles. So keep this in mine with your comments, be gentle guys.
) and open it. There should be a label inside that lists the terminals. Using a paperclip, jump terminals TE1 & E1 (BE ABSOLUTELY CERTAIN THAT YOU DO NOT JUMP ANY OTHER TERMINALS TOGETHER!!!). With the paperclip connecting terminals TE1 & E1, insert the key into the ignition and turn it to the accessory setting (do not completely start engine, just make all of the dash lights come on). The Check Engine Light should start to flash. Count the flashes and write them down. For me, it flashed 7 times, paused, then flashed 1 time, then paused again. The code will continue to repeat itself or register an additional code. Once all codes have been recorded, turn the key and remove it. Remove the paperclip and if you want to clear the CEL, pull the EFI 15A fuse for about 60 seconds. The engine will idle low (~400 rpms) for about a day while it "relearns" it settings.
