engine knocking
oahu, hawaii
just timed my 91 fj80 with 144560 miles, got it to match the 0 on the fly wheel with the stick on the tranny cover, pick up and speed improved 10 fold. (obviously was timed retard prior). on flat road's and moderate inclines the engine runs smooth does not knock., on steeper inclines, slightly hilly road's the engine knocks with lack of some power. after leveling off, no knock engine runs smooth. (engine never knocked previously when timed in the retard mode when going up same inclines.) could the timing still be off ? or something else? any info is appreciated.:confused:
Had you jumped your diagnostic terminals TE1 and E1 before setting ? Were your Dist advance vac lines plugged ? I do not think the mark you are shooting for is zero, it is 7 if I recall but check on your under hood label to be sure.
to my understanding on the flywheel the 0= 7 degrees btdc and the two small horizontal : = tdc? did use the jumper between ports according to the manual, i believe no need to plug any lines.will try again to see if something else happens?
