Engine Knock - Troubleshoot Assist Request!
Atlanta, GA
Woke up this am to a Knock Knock Knock at idle while helping a neighbor jump start his car...
Ryan Reynolds has about 252k miles on the clock and gets regular oil changes, etc... & yes, Ryan Reynolds is the name. My wife could never be mad at that guy so it seemed like an obvious name for something that will certainly cost us more time and $$$ than she would ever believe is appropriate.
So, to the Mud team, before I start taking something apart that I may not be qualified to reassemble, are there any suggestions or theories?
Thank you!
Make your video public. We can't see it.
Does it knock more with any throttle?
If you went through cyl by cyl pulling plug wires (and reconnecting) does the knock go away?
I'd start by taking off the belts and checking each pulley bearing, water pump etc... Run it briefly without the belts see if the noise is still there.
I thought my engine was coming apart (similar noise), but it was the idler and AC tensioner pulley bearings failing.
Good luck!
Update! Thank you all for the comments and the PM's! I pulled the AC idler pulley, fired it up and no tap tap tap! SO, with any luck and an inexpensive part, Ole' Ryan will be back in the game! This of course could also be the AC compressor but I'll save that rant for another evening. Mud for the win!
