Alright with the confusion I had on the year of the 40 I got it looks like I may be having the same thing with the engine. I have not found any #'s on the block where they are supposed to be. The reason I question things is I now know the 40 is production 65 titled as a 66. So assume 66 for year. has decal F155 so assuming F series.
It has a 2 bbl carb on it for one, everything I see says it should be 1 bbl.
I was reading literature about the oil canister thing that they used to use. Says that was used until 69' Is this correct. Did some come with them and some not. because mine has a standard style oil filter right in front of the clutch master with 2 lines running down to block. believe it is mounted onto the manifold. Just trying to figure out year info for engine parts. Even though I assume most all will swap with other years.
Thinking that they may have swapped engine stuff from the same 40 they swapped the fenders from that had the wrong vin tag on it. Hard to tell.
Any info??? Thanks Mike
