Engine harness plug
Omaha, NE
I’m in the middle of a head gasket job and found I have a connection that needs replacing. This was located near the starter below the PHH, I’m guessing leaking coolant fried it. I’m wondering why the female end has 7 wires and the male end has 8. Am I missing something?
Dunno about that plug but I've noticed a lot of chatter re: head gasket replacement on the 4.5. Do they go bad often or is this all preventative measures?
If you can find the plug on the EWD, that would help.
I found a small external leak on the back side of the engine a few months ago. I added some blue devil head gasket sealer and it never leaked another drop. I’ve got 3 weeks off of work this month so I planned on replacing the head gasket before a catastrophic failure. It’s my daily driver, so I figured I should take care of it. And yes it does seem like the head gasket has been an issue for several 1fz-fe’s.
I had the same type of issues on mine when I did it. Instead of replacing the entire plug I just pulled out the offending wires (2 in my case) and added them to a new waterproof plug. Yours looks a bit worse then mine did. Some of my connectors broke off due to corrosion. I bet you will find if you move the connectors at all they will break off as well. If I were to do it all over again I would have replaced that badly designed round plug with something like this.
https://www.amazon.com/Support-Waterproof-Electrical-Connector-Socket/dp/B014P8XLQM?tag=ihco-20
You could also head to the junk yard and find a 7-6 pin connector to swap in there.. Just cut the wires one at a time, solder, waterproof heat shrink. and insert into the new replacement plug.. Do it now as it will be almost impossible to do it after everything is back together.. And good luck with the HG.
Are you PERSONALLY gonna perform the head gasket replacement? If so, do a "diy" on it. I'd consider doing my own, if it's not TOO much of a bicth.
Nobody bothers to do a HG as PM anymore.
When it was a $20-30-40K rig it was a norm, but now it's too much $$$ for the average demographic owner here. If you bought it for $6-8K do you want to toss $1500+/15-25% purchase price at a HG?
It's like all 'Yotas, pop the OE HG & replace & you're GTG for life.
You choose when you do it.
Yeah I’m doing it myself along with a few other items while I’m i there. I have a new plug wired in already, I was just wondering why the factory plugs had an extra wire on the male end.
