Engine Compression Test Numbers
Al Ain, UAE
What is the acceptable range of numbers from a 1994 1FZ-FE engine compression test? Say, from new to used but still tight...
All I know is that you want to see even wear, so the numbers as close together as possible, but I don't know what the numbers mean. I searched and it seems 150-160 psi is good... here says the FSM calls for above 171psi and not below 128psi...
Are these numbers the same for any engine, since it's testing compression so volume doesn't matter?
Not any engine, that would be very low for a diesel engine.
A lot of things can change the numbers most of them differences in gauges, others like state of charge of the battery, weather etc. I had mine tested as part of a pre-purchase inspection, they were around 150, later I tested with my own gauge and had around 200.
So the variance cylinder to cylinder is more useful than the number itself.
