The previous owner stated that valves 5/6 on my 1994 were "bad" His mechanic told him he need rings on 5&6 cylinders and the heads rebuilt at a cost of 5k. I had someone (not a mechanic, just a cruiser head) look at it and they noticed a sound difference between 5&6 and the rest of the cylinders.
No indications of head gasket problems. No coolant in the oil and no oil that I can tell in the radiator fluid.
For those of you that know Colorado. I drove it from Erie, Colorado to Leadville.
The engine temp guage stayed at the 1/2 way mark the whole way including bumper to bumper on the tunnel approach and Fremont pass by Climax.
The oil pressure guage tracked with RPM and stayed at the 3/4 mark at 2500 rpm.
I checked the compression with a Harbor freight tool. I definitely had a leak as it would not hold pressure. All 6 cylinders where reading 120 psi or so. Spec is 171psi. I am guessing that my leak in my guage was causing the low readings. The guage would not hold the pressure. I had to have my wife turn the motor while I watched the guage to see its peak.
I do not see any white smoke, nor have I seen any blue smoke out the tailpipe. Spark plug number 6 was slightly fouled with oil. 1 through 5 were just were just well worn.
The engine has a definite lack of power and a slight miss. The transmission seems to shift fine.
I am going to take it to Safari Limited, but was trying to gather as much as could before I got there. The truck only has 164,000 miles on it. The previous owner had it for the last 100,000 miles. The coolant has been changed at least once, its green.
Is there anything else I should be looking at? Are my compression numbers low enough that I would see blowby and blue smoke out the tail pipe and oil consumption?
I really don't think my numbers are even close. The only time I saw pressure on the guage was when we cranked the motor. The guage "should" have held its peak reading. It just leaked down really quickly.
Howard
Howard
