Engine Compatibility
dnp
Supporting Vendor
Jackson, MS
I hate it when I don't bookmark something I read earlier, then can't find it again with a search!
I have a '95 80 that will be needing an engine (the PO partially disassembled the one in the truck, and I can tell some parts are missing). I will be looking for an entire USED engine assembly (long block)......that being said, what year 1FZ's are directly compatible? IIRC, a DIRECT swap for a 95 is 95-97. Is that right?
I don't want to have to modify/retrofit anything, so is '95 the cutoff date or can I go earlier than 95?
Thanks, and I'll try to do better about bookmarking in the future.
all 95+ with a mass air flow sensor(not that weird looking thing) will work.
94 and under wont without modification.
