Engine Compartment Heat Attrition
My high mileage '94 TLC is showing signs of heat attrition in the engine compartment. I've had to replace the insulation on various hoses and repair the large rubber air intake from the air cleaner to the engine.
Anybody else experience this and what have you had to replace or repair?
Thanks,
Bob
San Diego
lots of people have had to replace the rubber hose from the air cleaner. You admit you have a high mileage 94 (I'm in the same boat) which probably could use a few new hoses. Probably should replace PCV grommet, valve, and the two hoses on top of your valve cover. Read about the PCV valve grommet in the FAQ's to find out methods of keeping it from falling into the hole. The whole bottom part of my grommet was missing guess the motor ate it! Truck still runs.
