Engine compartment cleaning
South Kansas City, MO
Whats the best way to clean the engine compartment so it looks sparkling new. Leaking valve cover and years of road grime need to go.
I spray mine with full strength simple green let it soak for a few minutes then spray it off. I only do this when the engine is cold.
Seems like I remember reading something about simple green being bad for aluminum, but I've been doing this for 10 years and everything looks fine.
aaron
Two things I'd mention.
If you use a commercial high pressure washer to do this, most do not want you to use the engine degreaser products that you get at auto parts stores. And if you were using simple green, they wouldn't know the difference even though it's much friendlier to their systems, or the drain or the environment or what ever it is they're worried about.
Second, be sure you're comfortable with taking off the distributor cap to dry it out because almost without fail, it'll get water in there and you'll have a misfire. Do this before you restart for the first time.
I just went to my friendly neighborhood hand car wash and for $30 they spray degreaser all over and the use a pressure washer. They cover the coil and the dist. cap and t hen blast away. I couldn't believe how clean it got the engine and undercarriage
do a search under the user name Turbocruiser.
I can't recall what it is that he uses but you could serve the queen of england of his engine compartment and he keeps it that way all the time. course he also has a level of attention in these matters that is borderline OCD........
Here is another good tip on this......
After cleaning your engine area with degreaser, etc. you can get a bottle of formula 2001 (it comes in a green bottle) compares to armoral. Anyway, delute it down to 50% water and 50% actual formula 2001. Spray it all over you entire engine........everything. Hoses, metal, rubber, etc etc. Close down the hood and let it dry. I will soak up and leave the engine compartment shiny (im talking BRAND NEW looking!). The stuff will help the hoses not crack and will make the mud that gets flung up in the engine compartment come off way easier the next time! (dont ask me how I know this!:steer:)
Give it a try, im serious, this s*** works great!
Cheers,
Chans
