Engine bogs in midrange
On my 74 FJ40 F2 motor w/ orig carb --as I accelerate the low RPM range is fine, midrange bogs down and engine sputters a bit (sounds carb like) and then as RPMs increase it runs fine. Is this normal for cruisers? If not, what should I check / do?
I would check the fuel pump and filters. It sounds like fuel delivery to me. How long has it been since you did a tune-up? It could also be worth checking the timing.
here's another 2¢: check your vacuum lines for leaks, etc... a vacuum/timing advance issue?
just more pennies on your pile,
-dogboy- '87 FJ60
