Engine Bearings
Colorado
Rebuilding a 305 for my LC, the engine looks good but I had to teardown to clean up. During the teardown all of the tolerences are within spec. I am just gonna put it back together and I was going to replace the bearings, rings, ect... just because it would be a shame not to with the engine completely apart.
What bearing do I order? No mill work has been done. I think the choices are:
60 over
40 over
30 over
20 over
10 over
001 over
001 under
ect...
Opinions on what brands to watch out for would be appreciated too.
Thanks.
You will need to measure what was removed, and replace it with what came out bud....
Unless there is a name and part number on the bearings, I do not know of any other way other than to measure the old bearings with a ball micrometer, find out what they are from that, and order them up.
Good luck!
-Steve
Also, the .001" bearings are offered for your situation, assuming no previous machine work. Just tighten up the tolerances slightly. You need to make sure there is room for them though. Plasti-gauge is designed for that purpose but I could never get the hang of that damn stuff.
Did you check for out-of-round on all the journals? You're using a micrometer, right? You have a manual with tolerances?
For rings, measure the cylinder diameters (and roundness). One option is to buy oversize and file the ends to get the correct clearance.
That's all I know and it ain't much.
Oversize bearings are THICKER....what is filing the ends of it going to do?
A couple pics of a ball mic and a normal micrometer....and the ball mic in ACTION :)
Sweet, thanks for all the info, I will have to get me a ball mic. Everything is checking ok, round or in tolerance. I have a manual, but the common theme with the measurements seems to be consistancy. Like the valve spings, make sure they all measure within a certain spec of each other, ect...
It's a gamble for sure, not having a machine shop go through the motor. I figured a savings of $500 - 700 by not, and I told myself I would check everything and fix whatever was not in tolerance.
What is the opinion of just running the old bearings?
All of the rod bearings only have the shiny spot on the top, and none of the bearings have any gouges, scratches or funny wear indicators.
Thanks
