Engine bay connector (ground??) disconnected
Houston, TX
While moving around from driver side to front to passenger side, back to driver side, etc... trying to find the best way to get access to the water valve today I happened to look down and notice this connector is disconnected. Far as I can tell, everything works fine on the truck (except the front speakers but I doubt it's related) so I didn't plug it in (ain't broke don't fix it mentality). Can someone clue me in to what it is?
It's a ground from the engine to the driver fender well. It's not super critical, but I would reconnect it.Follow the female end and
it should be connect to the wheel well.
I did trace it back to where it terminates at the wheel well just under the charcoal canister. Thanks. Gave both ends a shot of electrical cleaner and plugged it back in. Now we'll see if the bigger gains are in hp or mpg.
