After installing the kick a$$ compressor mount from Landcruiserphil, i had to move my plug for my fridge. It was being blocked by the air compressor. I did that last weekend.
After finishing that, i was out and about and stopped by whole foods to pick up some goods, came out and wanted to toss a few items in the fridge since i wasn't going directly home. Plugged in the fridge and it did not turn on.
So now i'm trouble shooting and here is what i've found:
I am getting voltage to the 12v plug outlet mounted in the cruiser.
If i plug in any other type of 12v plug into the outlet, it works.
I pulled the fuse out of the Fridge cable, the fuse appears to be fine and not burnt.
I pulled the 10amp fuse out of the back of the fridge and it's fine.
The cable visually looks fine. No cuts or loose wires.
Somehow, it appears that i'm losing current in the fridge cable.
Anyone has any pointers?
As you can see in the attached pics, i took the fuse out to check it. Also, i tried to use my volt meter plugged into the female end of the fridge cable and my volt meter just kind of jumps around in mV and i don't know why. I have tried the + & - in the top two slots, i've tried the + in the top slot and the - in the lower slot and i don't get any consistent reading.
Any help would be appreciated since i'm not really an electrical genius.
