emmissions part - where does it go
That looks like the VTV that goes from right in front on the valve cover to the main advance port on the distributor. My FSM shows the brown side towards the advancer port. The main advance port in the one closest to the base of the distributor, or farthest from the cap -- whichever way you look at it.
If you go by the diagram on Emiisions Control System book, page 3-10 SC System, it shows the brown one there, but if you use the diagram on3-3 it shows the blue one there. I have the blue one there now, but where does the second one go. I only count 3 VTVs but I have an extra one. If you use page 3-3 component layout and schematic drawing I have all those VTVs covered, but still have the extra brown one.
yea, red is the wrong one:
the fj60 has one green, two blue, and the small black/white one at front of valve cover.
here is a chart showing the vacume presh for the different colors
i would assume that whoever changed it might of replaced the green with it, since the cc/min is "close"
beaufort-fj60 said:
it's the wrong part.
you need one green and two blue
beauforts right. i just went through this. go to your dealer and have them pull up the schematic for those and then match the part numbers. thats what i did.
I know. you would think that. I figure it should be easy enough for me to find the spot that needs hose of that length but I can't find an empty spot anywhere. Just got off the phone with CDAN and he said it isn't a 60 part #. supra, tercel and some 79 era 40s and 55s used the part number. I guess I will throw it in the tool box and hope I find an empty place for it one day. :confused:
I just double checked my manual, and you're absolutely correct. :) I'm glad my 60 only came with three -- took all the brainwork out when I put it all back together.
