Emissions Results
AJP
Not sure if any one is interested but here is some trivia..
Just had my "Drive Clean" test done this evening on my '97 LX450. This is mandatory every 2 years here in Ontario Canada.
235,836K km
Two Speed Idle Tailpipe Emission Results
2500 RPM
.............Limit......... Reading.......... Result
HC ppm ..200................ 9............. PASS
CO%...... 1.00............. 0.00 ..........PASS
NO ppm.... n/a.............. n/a............ n/a
RPM 2625..................................... valid
Dilution 14.7.................................. valid
IDLE RPM
...............Limit......... Reading......... Result
HC ppm...... 200............. 16............ PASS
CO% ..........1.00.......... 0.00 ...........PASS
NO ppm .......n/a ............n/a .............n/a
RPM 670........................................ valid
Dilution 14.7................................... valid
The only other comment was "Gas Cap Pressure Test" PASS
Wouldn't have passed the gas cap test if I hadn't got a new one from Dan in a "care package" ... along with the new gas tank filler neck that got installed last summer (after being bisected first :wrench:)
Anyway the young fellow that ran the test stopped briefly as he returned the keys to the service manager and said "passed with flying colors" ... that was it.
not sure if there was anything special here but I have pretty much stuck to synthetic religiously since buying it .. changed with filter (Toyota) every 5-6k km and put in a new PCV valve recently..new plugs and air filter last August... oh and replaced the "leaking like a sieve due to corrosion" gas tank filler neck earlier in the summer...and I only use Regular fuel .. although was toying with the idea of filling up with premium b4 the test... but didn't have the time.
Anyway - hopefully good for another two years
Nice test results. Keeping up on maintenance will definitely make it a heckuva lot easier to pass the test.
In contrast to WoodyFJ80's results, I'd think your truck was at correct operating temps for the test.
The test process in both cases is identical . . . but you have to meet slightly stricter cutpoints in Ontario. Your limit was 200ppm for HC and WoodyFJ80's limit was 220ppm, as an example.
