Emissions problems with FJZ80s?
Boulder, CO
I'm looking at a 1995 FJZ80 that appears to have been well treated. No leaks of any kind, good interior, almost all stock.
What are the odds I will have problems passing emissions? I live in Boulder, CO, where they are strict.
I would like to avoid the nightmare I went through getting my FJ60 to pass.
I would think little to none. Being a 95 w/ obd compliance and cpu control plus the numerous members in your area drivin the same truck. If its running well, no CEL, and all guages appear normal id say your good to go. Any reason for the concern other than your past experiance w/ the 60? smoke or smell at start up or heavy throttle?
great name btw!!
Unless I miss my guess, your MIL, (check engine light) will be lit if there is any problems with the O2 sensors. I live in Calif. and we too have strict emissions. I have not had any problems passing smog with my '93. I also drive a '96 Previa van for a commuter, and we had an O2 sensor go out once. Got hold of an OBDII checker, diagnosed the problem, and fixed it easily. You should be fine. BTW, in Calif, it is the responsibility of the seller to ensure that the vehicle passes smog. If that is the case in Co, than just make sure the seller understands that, and buy the thing...
So far, I've had no prob with mine; E/W a super charger. Engine is stock other wise.
I just got mine done in Boulder last week and passed with flying colors. I had no CEL's, and everything is stock on my rig. My only real fear of getting the emissions done is the guy who is testing it driving off the dyno...
Great information- thanks to everyone.
No check engine light coming on. No bad smells or smoke at startup or otherwise.
I called Air Care Colorado and they confirmed that it is the seller's responsibility to have the vehicle pass emissions. In fact, he said the seller is better off to take it to emissions testing himself before it leaves his posession. Then he just hands over the test results and I can go get plates.
I was mainly concerned because of the rust on the inline cats:
But if it's seller's responsibility, I'm not going to worry.
I wondered about when I got mine smogged. They didn't use the dyno. Just tested it at different RPM levels. The computer tells the mechanic everything he needs to know about how to do the smog check, per vehicle type/year. It wouldn't hurt to remind the tech before he starts that your truck is constant 4WD, just in case.
