Emissions Nightmare...Chip??
Alamance County, NC
:mad: Help. I drive a 97 FJ80 in NC and use it daily in my work (I sell land). It has ~150 K miles on her and she serves me well. For the past 3-4 years at the time for the DMV Inspection, emissions codes indicate I need to spend $$$ to pass. Twice, I have repalaced the O2 Sensor. I have also replaced the VSV and recently the EGR. All work was performed by a certified Toyota mechanic. Following replacement of all parts, the "check engine" light went off for ~ 1 week and came back on.
Why the Inspection people cannot just hook something up tp the exhaust pipe and test the vehicle, I will never understand but they cannot. The truck seems to run well (sans occasional spark-knock) and I am convinced the problem is in the vehicle's computer and not the engine.
I am told by motorheads that their are chips that bypass all the emission crap taht will make the vehicle pass the inspection. I do not want to install something that will screw-up the truck and cause her to drink more gas than she currently enjoys. If a chip is the answer, what kind do I get?
The results from the last emissions test shoe "complete" for Misfire Status,Fuel Status,and Comprehensive Status. "Not Complete" for Catalyst Status, and "Not Available" for Heated Catalyst Status, Evaporative, and Secondary Air Status. "Complete" for Oxygen and Oxygen Heater Status. Lastly, "NOT COMPLETE" for EGR Status. Code: PO401=EGR Flow Insufficient Detected.
I am not a mechanic by any means. I have a hard time turning on the DVD.
Thanks.
It might help everyone to know what state you live in and what code the ECU is throwing to cause the CEL.
:beer:
Why I won't ever buy a OBDII right here....
Gold :cheers:
I am told by motorheads that their are chips that bypass all the emission **** taht will make the vehicle pass the inspection. I do not want to install something that will screw-up the truck and cause her to drink more gas than she currently enjoys. If a chip is the answer, what kind do I get?
Thanks.
Never heard of it...:confused:
and a blip of a thought crossed my mind that could be a source for all that you mentioned...and the reason fixing what the codes tell you wont hold.
Bad fuel?
Having seen the inside of my throttle body and more importantly the crud built up inside the EGR port in the intake manifold, that would be my first project. Pull the TB and clean it up. Pay special attention to the EGR port where it enters the intake manifold (see the build-up of gunk in the picture). Clean that out using TB cleaner and whatever brushes/picks/screwdrivers you have. Also, you can remove the EGR temp sensor and try to clean in that section of the tube.
I'd order a new TB gasket (22271-66010) and the two coolant hoses (16261-66040, 16264-66021) that run to the TB (mine were pretty old and crumbly). Fairly simple project, probably about an hour :cheers:
I wish
Thanks for the suggestion. I do not knowingly buy cheap gas and try to stick to BP, Shell, or Citgo. I do stick with regular 87 octane gas. Could running some premium or octanne boost through her help?
Thanks very much but I need more pics. Where the hell are these parts and what do they look like? I am a mechanical idiot. I can 4 X 4 all day long (with a mechanic nearby), winch her out of mud over the flares, and change the oil. That's about it. I appreciate the suggestion and the help.
I see your in/around Mebane. Lemme pm another local member as he had suggested to me a mechanic in the area familiar w/ cruisers. Hes not fast, but educated and thorough; are you pressed to have this done immediately in order to pass your inspection??? Also, there is a NC chapter that has a thread about local recommended mechanics. Also there have been several threads lately concerning the EGR and code 401, as well as how to (and how not to) clean the system. even if you dont tackle it yourself, its worth printing off some info for a TRUSTED mechanic to follow, might save him some time and you some money.
nc club NC- Olde North State Cruisers - IH8MUD™ Forums
local mechanic thread https://forum.ih8mud.com/nc-olde-north-state-cruisers/88269-local-shops-your-area.html
x2 on not thinking a chip will be your answer
edit: landman try using some of the terms listed above and searching threads in 80's tech w/ each (ie EGR, 401, TB etc)
I would really appreciate it. Yes, I am near Mebane and my 08 Inspection expired in Jan 08. I am now being fined by the State and this is my only car. I am getting tired of saying prayers every time I pass a law enforcement officer but it must work as I have yet to get a ticket. Hope I did not just jinx myself. I have spoken to the people who sent me the nice "you are being fined" letter, told them the history, and while they are nice and understanding, offer no help except repeat what I have already done. I have even talked to members of the State Legislature and they do not have a clue either. You can get a yearly waiver after proving you spent over $200.00 every year. I do not have $200.00 PLUS the Inspection fee to blow every year. I love my LC and have no intention of ever selling it.
LandMan--- heres what i found out. Hope he might be able to help, but remember it may not be same day service, but you can ask.
Jeff at Toyz Unlimited in Liberty. He specializes in Toyota and Lexus ( Toyz Unlimited Toyota, Lexus, and Scion Specialists )
Then you need to find a trusted mechanic that will help you service it.
You have a P0401 code which is a failure in the EGR system. There are 4 components in the system plus the interconnecting hoses and wiring. Some failures are simply clogged ports or hoses. Many, many failures are the VSV for EGR. Others are the EGR modulator. A trained mechanic should be able to isolate the failure pretty quickly.
If you need to do this repair yourself then be patient and do a search her in the 80-section of 'Mud. There are many threads (including yours now) that discuss this problem. You will have to separate the wheat from the chafe due to the high number of threads started by those that post before they search.
-B-
