Ok, got the manifold leak cured in the 78 FJ55 w/ OEM double gaskets. Start putting everything back together and found that the PO had ignored the two nipples on the carb heat riser (nice contributor to my vacuum leak no doubt). I'm using the FSM for emissions to try to connect the vapor recovery circuit and the spark advance - most of the other emissions stuff is gone (no air pump/air rail). I'm guessing that the hose from the VSV in the fuel recovery connects to one of the two ports in the carb heat riser but what about the second port? Can anyone please stear me in the right direction.
Thanks,
Ming
Thanks,
Ming
