Hello, I have a 85 w/ 5 speed and am in the process of trying to pass smog.
Question #1 On the 2 vacuum hoses that leave the distributor cap, one goes to the VCV (vacuum control valve) the other is to go to the air filter, I cannot seem to find the fitting for it , the only nipples I have found (on the air filter housing) are for the HIC (Hot Idle Compensation) valve. Is there a fitting I'm missing, I failed the visual part on that'
Question #2 Passed the 15 mph @ 1756 rpm's the numbers are...
CO2 14.43 / O2 1.01 / HC 63 / CO .27 /NO 118
FAILED the 25 mph @ 1691 rpm's
CO2 14.00 / O2 0.47 / HC 13 / CO 1.15 / NO 72
After the hose is routed correctly any clues on where to start?
Thanks, Scott
Thanks, Scott
