Emergency Help - Wheel Stud Replacement
Last weekend I picked up a '94 Crusier to part out (with lockers!).
You probably already know this but in case you or someone reading doesn't know, the wheels and lug nuts on the 93-94 are different from the 95-97. You can swap wheels but you MUST use the lug nuts that go with the wheels.
(edited for clarity)
-B-
You probably already know this but in case you or someone reading doesn't know, the wheels and lugs on the 93-94 are different from the 95-97. You can swap wheels but you MUST use the lugs that go with the wheels.
-B-
Lugs or lug NUTS? I thought the only difference was the "shank" type lug nuts for the 95-97 vs. the conical lug nut seats on the 93-94...?
Lug nuts, not the wheel studs.
-B-
-B-
I def second this!!! I just put a set of 95-97 rims w/ 35" tires on my truck, but dent have the proper lug nuts yet, so I put my 93-94 lug nuts on temporarily... Apparently not temporarily enough. Broke a stud yesterday on my front D/S. Def be sure to use the right lug nuts and don't think that you will be fine for a little but without them.
Also, do you guys know if I will have to tear it down to the axle to replace a front tire stud... Seems the consensus is no on the rear. How about the front?
