92 fj80 overheated going up a hill... Pulled over, coolant was boiling but nothing leaking anywhere. Oil looks fine, but car won't start. Battery is ok, but when I turn the key nothing happens. No crank, nothing. Ideas?
Turn the key to the "on" position. But don't actually turn it on. Do you get the Check Engine Light (orange engine light on the gauge cluster)? I'm guessing, no.
Like the PO said, let it cool down. Your EFI relay is probably overheated.
Now, the question is, "why are you overheating?" How hot out? How quickly did it overheat? What did you do to try to cool it down? Is everything "stock" as far as fan, shroud, fan clutch, etc? Where are you?
Whack the starter with a BFH or wrench while cranking (you'll need someone to help you as they have to crank while you hit it).
I don't think starter though. Unless you've been having problems prior to this. Starters typically go when it's cold and they stick.
I have no idea where that is that you are located. Nearest "city", in what state?
Maybe @jonheld or @Tools R Us are online and can help. Those two know literally EVERYTHING.
