Emergency Hazard Switch help/advice
Loxahatchee, FL U.S.A.
I plan to use the emergency hazard switch as an on off switch for an aftermarket fuel pump. Can anyone help with wich wires to use and which I can remove from the pitail?
Below are pics of the switch and pigtail.
If anyone has the wiring identification for this switch, that would be perfect.
You probably have a few options. Do you have a multimeter?
Make sure you use a relay. Do not run the pump voltage through the switch.
Standard Bosch or Tyco 30a
Look for 85 30 86 87 87a on the connectors.
Thanks so much. I cam across your post for labeling the switch to AUX FUEL Tank. I do not have a printer. Is there someone that can print labels and send them to me? I can pay through Paypal.
I also posted the request on the Switch Relabel Post.
Thanks
