Elocker safety disabling ?s
Got the rear locker hooked up. Problem is it only engages when the cdl is pushed. Im now part time and dont wanna engage 4wd just to run the rear locker. Can that safety be bypassed. I did a search but to no avail.
It looks like i should be able to remove or ground the pin (i believe its pin 13) that controls this.
Has anybody done it, or does anybody know where i can find the info. Ive found tons of links, but they were all retrofit threads and the like.
Thanks in advance.
Will
pin 7 mod?
Look up "pin 7 mod" as blume points out and you'll find how the system is modified for completely independant use of any locker, high range or low.
DougM
the reason you press the center diff lock button is because it changes your Awd truck to a 50/50 4x4. If that makes sense to you.
Now if you were to put the rear locker on when you didn't have the cdl on you would simply be getting no where.
How hard it it to press a button before you turn the dial one click? You can still engage it in high.
The Pin 7 mod just removes the low range input from the diff lock ECU so it doesn't automatically lock the CDL when shifted to low. It is a good mod, but it won't have the desired effect here (lock FR or RR lockers independently of CDL). And since he is running part time, he does not need to lock the CDL to get full power to the (rear) wheels.
In my 96 EWD, it looks like the pink/black stripe wire that runs from splice point I6 to Pin 15 of the diff lock ECU is the one that provides the ground signal telling it that the CDL is locked. If you were to cut that wire from the splice point and ground Pin 15, the diff lock ECU should think that the CDL is locked and will let you lock the FR and RR lockers as you please (below 5 mph). This will also isolate it from the CDL dashboard light, which should still light up when the CDL is actually locked. I don't know if the wire colours correspond to a 93 though, but the idea is the same.
I'm no mechanic or electrical guru, but that's most likely what I would try. HTH!
96r50
Thanks a ton. My EWD is on order.
Will
