electronic/ac pump guys
Suburban Hell
I have an ac compressor from an 8x's volvo. I am trying (unsuccessfully) to bench test. I have a 12 volt power supply hooked up to it, the clutch engages but it does not spin. What am I doing wrong?
With the clutch engaged, you should be able to turn the compressor by hand (as long as the fittings on top are clear - no closed valves still mounted on top)
While spinning the compressor by hand, with the clutch engaged, you should be able to cover one of the holes on top with your finger and feel that one hole will have suction and the other will have pressure.
With the clutch engaged, and you have pressure on one of the fittings while spinning the pulley, then it is good.
Ok, clarification time. My first post is so conveluted and chock full of incorrect info. As stated before too many step #6.
In addition to the rotary pumps I was playing with two air bag pumps from Lincolns. I was thinking of this as another option. I don't know how they flow but I can mount both of them. It would be easier to plumb and hook up. Even if they dont flow real well I would have 2 of them to speed up tire inflation.
The air bag pumps are the ones I couldnt get to work. Fire Dog pointd out that my power source didn't have enough amps to turn the motors. They seem pretty small so I thought it would work. I will try to hook them to a car battery to see it I can get them to pump.
Does anyone have any info on these air bag pumps?
