Electrically Sick 75 FJ40
OK guys, I gotta butt in here because I am the PO. If you check previous posts you will read where pin head helped me locate what I believed to be the source of the electrical problem. When I got the rig home from a 3 year resto in a nearby shop, ( I did it at my convenience) The motor would drag like the battery was dead. So I posted asking what could be the cause of this? I got several responses which lead me to replace the battery and battery cables and wire brush all frame connections. That solved the slow turn over but when I started the rig after that it smoked the wire that goes from the positive battery cable to the coil. IIRC. Pin head suggested i remove the ballast resistor from the mounting frame and I did and that solved that problem. The inline fuse was placed there due to the smoking wire problem and didn't want it to affect any other components. However, the black wire from the coil has some bare insulation on it and would ground out on the battery support post and that would blow the inline fuse and shut the rig down. I didnt have time to fix that so it should be looked at. Also the ballast resistor could be the culprit but I am not sure. Thought if I posted this info it would help. There were no problems at all with this rig prior to going into resto. As far as the fuel pump, there was an electric pump on the rig when I bought it about 9 years ago and replaced it prior to selling it just because it had sat so long. I wired it up the way the PO had it done. Ground to Neg, battery cable and Hot to hot side on coil. Probably a better way to hook it up but that is the way it was done previously with no problems. This will give you guys more info on helping with this problem. Mike, Please email me if you have problems/ questions that I can help you with. I want you to be happy with your purchase.
