Electrical ?'s possible keyless entry
Can anyone tell me what the black box under the driver seat is? It says security. Is it the keyless entry system? They PO told me it did not come with that feature, so I bought a set up. I have not installed it yet, I began to but I saw that. So my question is, is that the keyless entry system. Can you get new key fobs? What are the functions of the wires by color if I wanted to install the new unit, could I tap in there
It seems like it is the keyless entry, Does any one know how much the fobs are form the dealer or C-Dan
You bpught a "set-up" without looking under the seat? The PO says " didnt come with that feature", meaning, "when I bought it I never got a key fob". Call Dan, get a key fob for your truck, and I would bet that it chirps right up. I went a year without a fob for my truck, got one from a club member, and minutes later I was locking and unlocking my truck, hearing the chirps and seeing the lights flash, outside and inside the truck. I wouldnt mess with a single wire before you got a key fob. I take it your "set-up didnt include one.
on the black box under the seat, there is a little green button on the side. push and hold that button for 5 seconds. if the security light on your dash lights up, then all you need is a key fob. cdan sells them for $63 new. you can also get a used one on ebay or in the classifieds here on the forum. find someone close to you that has one and try to program their remote to your truck, it takes all of 20 seconds. if it works, just get a key fob and don't touch any wires. my black box under the seat went bad and i picked up a working one from the junk yard for $15. my case was a rare as these don't usually go bad. fix what you've got before cutting wires.
Agreed. So i got the original key fob from dan and I am unlocking and locking the doors just fine. One Issue that has arisen is I now do not have front parking lights. Any thoughts?
Check the bulbs. My driver side bulb went out causing both to fail. Replace the DS and both work fine again. Just a random thought to check.
