- Thread starter
- #21
Finally got around to testing the truck. I kept the digital meter. First on the using a 20V DC setting, the battery was at 10.6v. I jumped the truck (didn't take much) and retested with the engine at idle. The battery was above 13 and the output cable off the alternater was 14.8V. After 20 minutes of driving the battery was at 13.4V. I took off the negative cable and went to bed for the night assuming battery is OK, the alternater is charging adequately. When I tested it again this morning the voltage had dropped to 11.3 volts and the truck barely started. What does this mean as the battery was not connected overnight--not possible to drain when the ground is disconnected right?
So I run the truck and the voltage is again above 13 on the battery (tested to fame ground and between posts). QUESTION--will a battery not have enough juice to turn the starter below some threshold number (i.e. 12 volts)? Its not like my battery is dead becuase all I need to do is place jumpers from my 80 (engine off) and it fires up first turn of the key.
I disconnect the + cable and place the meter leades between the post and terminal. Set to the 20mA setting with the leads switched up I get a reading of 0.5 with the key off and out. I start removing fuses and the only change is when I take out the lighter fuse and it drops to 0.2 (is this a significant drain?). Shouldn't I be at 0.0 if all is well anyway? So problem solved right? I leave the fuse out (now my interior lights and high beam indicater don't work (tipped off from the wiring diagram) but thats ok. The truck sits for about an hour and when I go to start it up it turns over a few times, I pop the clutch and am off to work....now the truck is parked on a hill and I am writting this post.
Any tips? What physically happens to cause a drain? It an exposed hot wire grounding out on metal---what should I be looking for? Remember, if I drive this truck consistently (don't let it sit for a couple of days then I never had this problem (took 8 months for me to realize it as I drove another car for a week). Thanks for the help.
