71 FJ40 turn signals would not work. I removed the TS switch and took it apart cleaned the contacts bench tested it and now works smooth. My problem is the supposed G/L wire that sends power to the Turn signal switch has no power. I checked the fuse panel and the inline fuse that comes off the Hazard switch off the panel and that checks out. I also checked the power that goes to the hazard switchbox and it gets power when key is switched on. I have traced the wire with no luck using the schematics.
My question is
Can I piggy back off the Hazard switch box (switched wire)
to power the turn signals?
or run a wire from the fuse panel switched side to power the turn signals?
bypass that G/L wire?
My question is
