I’ve got a 97 LX450. When I come up to a stop and turn on the turn signal, my D light dims a bit to the rhythm of the turn signal. Also, the headlights dim a bit when I operate the power windows. Is this a ground issue? If so, what connections should I check?
My rig did this, than I installed the updated slee wiring harness and the headlights stopped dimming when rolling the windows up or whenever the bass hit.
Made in the USA TXL wire – high heat resistance, abrasion resistant, chemical resistant, highly flexible Genuine Delphi sealed headlamp connectors Techflex abrasion resistant braided sleeving with ends terminated with shrink tube Beuler 40 amp (60 peak) relays – US sourced Sealed blade fuses...
No click, stutter, or buzz. I have an Ultra Gauge, as well. I’ll set to monitor voltage. While I’ve got an ultra gauge user engaged, I’ve got another question…do you ever monitor short term and long term fuel trim? If so, what values do you see for STFT and LTFT? My LTFT is usually around +10 (+/-2) and STFT is always between -5 and +5. With ethanol-free gas I see LTFT around +7 to +9. Do these readings seem normal? I see FSM says +/- 20 FT readings are OK.
Awesome! I live in the salt belt- Indiana. Daily most days in warm months. Store in winter. If you could grab your fuel trims, I’d appreciate it. Are you running original engine? I’ve never tracked my overall MPGs, but I will next time I fuel. I’m running a 2” lift and 295 tires with ARB bull bar. Can’t think my MPGs are much different than yours.
Nope. I believe that the Photoman bracket is currently unavailable, but it's supposed to be available again soon. The alternator part numbers for the 130 and 150 amp alternators can be found in a thread here. There's also a rumor that a Jaguar alternator might be easily adaptable.
I understand that. I’m in the sawmill business and we have contractors that do the same for us. None that drive 80s, however. That’s pretty awesome that you daily it.
