Electrical problem ????
Socal/ I.E.
I removed my inner PS mirror today. And affter I put it back in I tryed to ajust it with the mirror ajustment controls, but they were not working. The radio and heater/AC are also not working. I checked the fuzes in the cabin, and also the ones in the engin bay. I found no problams with the fuzes. Am I missing somthing?
Please Help! Thanks.
"Inner" PS mirror? Is there an "outer" one? Here is the FSM for it. Can't help much more than that sorry.
Are you referring to the power mirror controls? If so, is there a chance you could have knocked something loose (like a wire) on the fuse block while you were in there since they are right next to each other?
It looks like the power mirrors and the radio have a common fuse (15A CIG), so you may want to check that one again.
First, I'd check to make sure all three wires are connected in the right order on your mirror. Then replace that fuse that goes to the mirror. It must be blown if all was good before you removed the mirror.
