Electrical Problem
BAJA CALIFORNIA
FIX .....Electrical Problem
I Have A 1997 Fj80, Radio, Clock,dome Light, Antena, Glove Box Not Workin, I Check Fuses, Grounds,all Are Ok I Check Power To Amp Is Ok I Power Probe Every Thing And It Works. Does Any Body Has An Idea were is the problem, or wath to check for
Foud wire OPEN L- Y BLUE-YELLOW in side engine comp. left fender wire harnes from fuse #2 10amp dome to junction conector J3 foun wires harnes damege
Gilberto,
Did you check the fuses in the fuse box located in the engine compartment?
Regards
Alvaro
If all of the fuses are OK there must be a common reason why they are all not working.
What have you done recently to the truck that might be close to the area of the problem?
Does your windscreen leak?
Fitted a radio?
If you have power at the accessories that don't work I would check to see if they share a common earth. The earth might not be grounded properly.
I would suspect it has something to do with the alarm.
Does it have features like automatic window roll up?
You might have a broken wire. Check the alarm cables.
Regards
Alvaro
