Electrical issues ?
Oregon
Had some electical issues iw. Tail lights , bent wire, bad connector/pins(male and female ) . have been ablw to work through them and have put everything back together abd install the DS seat. The PS seat i just took out to tighten up some things. The truck has turning over and staying witgout issue. Now with evwrything buttoned back up and only pássenger seat out the truck only will crank but not fire. Evwrything worked 5minutes ago. I still have everytning working electrically . Other than checking for a loose connection, what am i missing to check? ECM fuse? thanks in advance
IIRC, the "can't get out of park" fault is due to one of the rear lights--brake/tail. That shouldn't affect starting though.
There are 3 fuses to check first. 15 amp CIG; 15 amp ECU-IG; 10 amp STOP, all located in the fuse box by the driver's left knee. Check fuses with a meter, not your eyeballs.
Make sure your brake lights work when you step on the pedal.
There is a shift lock ECU under the center console (small circuit board with some logic and a relay). Make sure connections are not corroded from old spilled sodas over the last 25 years.
There is also a ground point under the center console. Make sure it is in good shape.
Make sure the release solenoid plunger moves freely and is not stuck in place by dried sugary drinks.
Also, your trailer wiring may be the culprit if you messed with any of that while back there...
Ok.ill start with your recomendations. Ihave had issues trailer lights and messed with them but thought those gremlins were taken care of.
Guess not........
Appearently
I'd start with the ground mentioned--it may be related to the removing the seats (not sure on this as I don't remember exactly where it is, but it seems most likely since the rig started before you took the seat out and did not start afterward)
Ok.i see tge ground goes into the ground under center console.so it could be the seat being out.
All the fuses check out ok.just no turn signal or brake lights. Everythjng under console is connected and plunger works fine. Other than seat still ou, still need to check wiring for trailer and tail lights
Any progress? I can't think of anything that would cause a crank, no start condition that has anything to do with the seat or center console. I'd take a look at the no start portion of the FAQ and see if you can narrow it down--it is possible that you just had a coincidental failure of something.
