electrical help!
I need some advice- I went in the mud in my 80 and now the batt's won't charge. The oil level/at temp/t-belt lights as well as the red and green turbo lights won't go out. - Any Ideas?
I washed the engine bay out but it didn't help. There's no power coming from the alternator but the charging light isn't coming on. look forward to advice. -Thx
Why did you feel that you needed to "wash out the engine bay"? Did the lights & no charging happen before or after you washed it out?
bay
The alternator and all the wiring was covered in mud. B4 I start chasing down this ground i need to see the wires.
OK, from your answer I'm assuming you had all problems before washing out, so that had to be done anyway. Sounds like if you haven't fried your alternator, it might be just the brushes. If you have electrical experience and the FSM, 1st disco your batteries. Then try pulling the brushes and make sure that area is dried out and clean. If it still has mud and or water, you might pull the alternator and dry it out. I think there's a checkout procedure for the alternator in the FSM.Also want to ohm out your wiring to be sure some thing else isn't shorting out your system, for example a light fixture might be full of water/mud. Keep us posted on your progress!
You can either replace the alt or clean out the brushes. My guess is you have one stuck or both stuck(brushes). A few months back some friends of mine played a trick on each other and covered a truck with mud bath. the alt had so much mud in it that when you spun it by hand you could hear the rock in it. So after removing the brushes (a field manual is great for this, os if you have no experience with taking a Alt apart, you may want to just get a reman one from toyota). I ran the alt under water to flush out the rocks and such. I even seperated the case a bit to allow some bigger rocks to get out. After this was done, I used air to blow dry it. The brushes I had to work under water as well, I also used a small pick to pry gently one of the brushes loose. After all is said and done, it worked and is still working. All this flushing was done with the alt out of the truck. Good luck.
