Electrical help in Front Range Colorado
Colorado
Hey everyone,
I have a 1976 FJ40 that needs the electrical redone. Can you recommend anyone to do troubleshooting/repair near Denver? So far the engine, electric fuel pump, and the heater blower motor all work. I replaced all the fuses. Nothing else works. No blinker, headlights, brake lights, etc. I want to get this monster registered and on the road.
Thanks!
You might post your questions in the appropriate CO clubhouse, HERE... perhaps a member will be able to help.
Okay Thanks Solace.
As a side note. I called Redline Cruisers in Colorado Springs. They recommended Scott over at Get Wired Automotive Solutions . I called him and he seemed very pleasant and ready to assist. I will let you know what I learn from the experience.
You know... you might save yourself some money by:
  • removing your fuse box and cleaning all the contacts... several people gave done this and documented it on here.
  • Cleaning your ground strap connections (especially, battery- to frame, behind the front PS wheel).
  • Cleaning light fixture grounds (most fixtures ground to the body).
  • Making sure you have good battery cables and clean battery terminals.
These are preventative maintenance issues on these old trucks... and performing them may solve some of your issues.
You can always proceed with professional help afterwards.
Good luck regardless!!
