Electrical Gremlins
NE Florida
My '95 has 213K on it and 40 of that I put on since I picked it up a year ago. I enjoy the view from the driver's seat regardless of how canted and disjointed it may end up but recently I have been having intermittent problems starting it. It will make the important Dairy Queen run and get home and not start the next time. Let it sit for 1 - 21 days and it starts right up and runs for a couple of trips then stops starting again. This has happened 4 times now (OK, not all were runs to the DQ) and I have done the following: check wiring and all fuses and battery. I can't take it to my electrical specialist because it runs fine or I have had it trailered over and it starts up when it arrives. What would cause and intermittent failure to start given there is electricity to the lights, radio, inside lights, etc? This is the most simple circuit on the car - before I put in a push buttin for starting it, are there any ideas? Thanks, Pete
Probly starter contacts. DO a quick search and you will find a wealth of info.....
I think there is even a no start section in the FAQ
I had the starter conections changed when I was on vacation and got stranded. Only lasted about two days before I was hung up again. I am looking for anything which would lock out the starting circuit. I only have a simple manual to work with but it appears to have all the circuits diagramed well. I took the left kick panel out and looked behind it and there have been some mods as two security systems were installed. I put one in and then the problems started so I had it taken out. There was an original system which was not OEM put in but didn't work so I treated it as benign. I am trying to find a connection which would loosen up while driving and then go back together if the machine were tilted up or rolled off a tow truck. This has happened 4 times where it was sent to the dealer (I have good insurance but its not going to do this again) and as it rolled off, the dealer started it up and drove it into the bay. Given the probs with solonoids, they just changed the contacts. All other times it has been a 'no charge but take it away' scenario. Circuit: yes; mechanical problem: probably. Thanks, Pete
We need more info. Does it turn over or does it just click? Do your lights dim while you try to start it? Does your check engine light come on every time just before you try to start it? Have you or have you had some else work on your truck? Intermittent problems like this usually indicate frayed or broken wires. I suspect the engine wire harness by cylinder 5 and 6 next to the egr tube. Read up on the thread linked below:
https://forum.ih8mud.com/showthread.php?t=115816
Karl
sounds like starter solenoid. mine was doing this and i didnt have time to mess with a rebuild so i replaced the whole starter assembly. no problem since...
I decided to go back to teaching and picked up a couple of 9th grade Biology classes. That and coaching the cross country team stopped my time on the internet and I put in a direct hot wire to the starter solonoid using a toggle switch. When the ignition doesn't crank it, I reach uner the dash and give it a twist and it goes mightily. When the ignition doesn't work, there is no sound, no click, no lights dimming, nothing but all the electrical connections (radio, ac fan, lights, etc) work like a champ. Most often, the front end is pointing uphill when it won't start. Doug
