electrical gremlin
windy wyoming
didn't find anything in searches, but you'd be surprised how vague the search results can be...
95 fjz80. had a mazda stereo in it when i got it, i put in a delphi, it appears aftermarket stereos were just spliced in to the stock wiring. factory amp is gone.
i blew the fuse to the radio twice, both in heavy rain. figured that was a plug hanging out of a rusthole on my rear quarter where the factory amp used to be. fixing this is how i learned the radio, dome lights and clock are all on the same circuit, but now my latest...
it's been dry all week. thursday morning, i get to work and my radio doesn't shut off with the ignition like it always has. i now have to manually shut off the radio. the power amp (which is wired to battery and ignition) does shut off. the dome lights work fine. the clock does not have power.
any ideas???
UmfdK
There is virtually no way that anyone is going to be able to troubleshoot this over the internet, but I can tell you that you have a short somewhere. As an industrial electrician, I can tell you that wires do some strange stuff...it is amazing what symptoms an intermittent short will produce!!
I'd suggest getting an electrical schematic of your system and start at the fuse box and work your way back checking as you go. Remember to disconnect your battery before using an ohm meter to check continuity!!
