Electrical Gremlin (or short) Help Request
Renton, PNW
So I purchased this truck with eyes wide open re: stereo mess. Sometime in early 2000's someone put in a ghetto fab stereo that by now was a complete POS. Jist of it was a DVD/TV double din unit with all sorts of holes in the door panels for extra speakers that were powered by amps in the back passenger storage compartment. Had I known interior panels are discontinued by Mr. T, I might have gone a different direction, but that's another story.
I took the old unit out looking to create a fresh install. No problem there, as my breaking and disassembling skills were acquired in grade school. I went to attach the new head to the old harness to test some of the original speakers, since the aftermarket job bypassed them. When I hooked up the head unit it worked fine. Then after a couple attaches/detaches it ceased getting power.
The "accessory" cable worked, but it wasn't getting power from the "power" whenever the key wasn't turned. So I pulled out the ol multimeter and tested all the wires from the harness and there was no juice in the power cable. Not sure how to fix this one. Rip the whole dash apart?
Additionally, I noticed that dash clock now only worked when the key was in "accessory" as well as the map light. After a couple weeks neglecting this issue due to life obligations I've noticed that occasionally while driving the dash clock will flash very dimly and the maplight doesn't work at all.
Any suggestions would be greatly appreciated.
The radio, clock and the map light all have one thing in common: they are all fed by the "DOME" fuse circuit. It's a 10A fuse you'll find in the fuse block under the hood. The DOME circuit is the BLUE/YELLOW wire and should always be "hot" when the key is off.
The radio and clock are also both fed by the "CIG" (15A) fuse circuit (GRAY wire). This circuit is the "accessory" circuit and is only "hot" when the key is in the accessory or "on" position.
I'd look behind the fuse panel (the one in the dash) and see what kind of carnage has been done back there.
I should have been more clear. I checked the fuses, none are blown.
The dash clock occasionally flashes on / off at about half the brightness of it when it was working. When I turn on the map light the flashing of the dash clock stops - it's just off.
Additionally, I just realized that the obnoxious "ding ding ding ding ding" that happens when I put the key in the ignition is also off.
Did You Know thread material :cheers:
Actually it appears I need to read more carefully.
Look at what @landcrshr said again. Not necessarily the fuses but all of the carnage BEHIND the fuse panel. They tapped in to something for power and very well could be those wires. Check them. And replace all of your fuses anyway. Fuses are cheap and you don't know the quality of the fuses that were used. Sometimes there are issues with fuses and they don't show blown. Just had it happen to me about a month ago with my gauge cluster.
Also fed by the "DOME" fuse.
Was your issue resolved? I have my DOME fuse blowing. No radio, dome or map light. However, my map light will flicker periodically while going over bumps (easier to see at night. So I obviously have a short somewhere, curious what your resolution was.
It was a blown fuse under the hood. I had blown it while installing the new stereo.
