electrical gremlin - need advice
Atlanta, GA
So for a while now I have had this issue. It appears that the automatic shift lock relay is being activated (clicking on and off) when I turn on the left signal. It for some reason is causing the left tailights to flash at the same time. Has anyone had the same problem? How to fix it?
The right blinker functions normally. I have tried various tail lights. Both LED and non LED. While I have gone through the wiring on most of the cruiser I have not gone through the wiring in the rear quarter panels. There is trailer wiring spliced in there somewhere which I want to redo.
Appreciate any insight!!
Pull the passenger side rear tail light and you can access the trailer splice tie in. It could be that splice or some bad trailer harness wiring. Maybe to wires are bare and rubbing together.
