Electrical Gremilin
Edmonton, AB
Hi guys,
Having an electrical issue that I need some help with. Electrical is not my strong point so hopefully someone knows how to fix this.
When I went away on vacation in September I came home to find the cruiser dead. It sat for about two weeks and was down to 4 volts. I have Die Hard Platinum AGM's so I got it charged up again with a battery tender and it died again in short order. This time I noticed that the green light around the ignition was on and wouldnt go out no matter what. I also noticed that I could turn on the head lights without the key in the ignition.
I figured out that the ignition light is on the dome fuse so I am now not killing the battery but need to figure this one out. I smacked the relays to see if one was stuck but no dice.
It was suggested by one of the local guys that I check the fusible links because those can cause strange issues. Replaced the link and no change.
Any suggestions where to look?
So what's your actual problem?
Headlights always work without key in ignition. I've yet to find a vehicle that isn't the case with...
The ring around the ignition is control by a timer module in the US PS footwell - a diode typically fails and causes the parasitic drain. Search mud for repairs. My repair -> Ignition dimming relay
cheers,
george.
cheers,
george.
perfect. that looks exactly like my problem. thanks.
